주요 콘텐츠로 건너뛰기
Canon PowerShot A590 IS Memory Card Replacement
  1. Canon PowerShot A590 IS Memory Card Replacement, Open the Battery Hatch: 1 단계, 이미지 1/1
    • Be gentle with the hatch, it is fragile.
    • *See battery replacement guide for help opening the hatch.
  2. Canon PowerShot A590 IS Memory Card Replacement, Locate Memory Card: 2 단계, 이미지 1/1
    • The memory card slot is shown here in the red rectangle.
  3. Canon PowerShot A590 IS Memory Card Replacement, Remove Memory Card: 3 단계, 이미지 1/1
    • To eject your memory card, simply press it into the camera gently, and it will spring out.
    • After it has been released from the camera, just pull it out.
  4. Canon PowerShot A590 IS Memory Card Replacement, Replace Memory Card: 4 단계, 이미지 1/1
    • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
    • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Zach
회원 가입일: 10/11/10
281 평판
안내서 6개 작성하였습니다
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 회원
CPSU-REGAN-F10S9G19
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 23
전체 시간: 5,587
