주요 콘텐츠로 건너뛰기
Canon PowerShot SD1400 IS Battery Replacement
필요한 것
  1. Canon PowerShot SD1400 IS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The battery compartment is located on the bottom of the camera, below the user interface panel.
  2. Canon PowerShot SD1400 IS Battery Replacement: 2 단계, 이미지 1개 중 1개
    • The hatch covering the memory card will slide open towards the corner of the device.
    Now that I feel like a blooming idiot, I can change the battery. Thank you very much.
    drdenny46 - 답글
    Thank you. How do I pay.
    drdenny46 - 답글
  3. Canon PowerShot SD1400 IS Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
  4. Canon PowerShot SD1400 IS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Once open, you will see a small orange tab near the corner of the camera.
    • Push this tab towards the front face of the device, and the battery will freely fall out from the hatch.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matt Holquist
회원 가입일: 02/01/18
157 평판
안내서 1개를 작성함
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G3
3 회원들
안내서 4개를 작성함
1 Guide Comment
Where do I go to pay?
drdenny46 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 53
전체 시간: 1,742
