주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SD780 IS Flash Capacitor Replacement
필요한 것
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Canon PowerShot SD780 IS Flash Capacitor Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SD780 IS Flash Capacitor Replacement: 2 단계, 이미지 2개 중 2개
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red square in the second image (on the left side in the first image) are 2.0 mm long.
  2. Canon PowerShot SD780 IS Flash Capacitor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Canon PowerShot SD780 IS Flash Capacitor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screw on the far left hand side of the camera.
  4. Canon PowerShot SD780 IS Flash Capacitor Replacement: 5 단계, 이미지 1개 중 1개
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Canon PowerShot SD780 IS Flash Capacitor Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. Canon PowerShot SD780 IS Flash Capacitor Replacement: 7 단계, 이미지 1개 중 1개
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Arlene Ale
회원 가입일: 03/13/14
455 평판
안내서 4개를 작성함
New Mexico State, Team 1-5, Easley Spring 2014 New Mexico State, Team 1-5, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G5
2 회원들
안내서 4개를 작성함
1가이드 댓글
what is the number for the replacement battery?
peterprosser - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 1,235
