소개
Replace the flash of the Canon PowerShot SX50 HS.
필요한 것
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
See the guide on this link for soldering and desoldering.
다른 한 분이 해당 안내서를 완성하였습니다.
5 Comments
Hello! excellent explanation . Thank you very much! I have a question : could you tell me where I can buy the replacement lamp ? I already tried searching online but can not find anywhere that sells it. Thank you very much , greetings !
I need a bulb, no one can tell where you can find a bulb, and it says no parts needed. that's stupid since you need a replacement bulb that you can't find. without it all this is useless.
