주요 콘텐츠로 건너뛰기
Canon Powershot A610 Speaker Replacement
필요한 것
  1. Canon Powershot A610 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Canon Powershot A610 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Canon Powershot A610 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: 3 단계, 이미지 1/1
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: 4 단계, 이미지 1/2 Canon Powershot A610 Speaker Replacement: 4 단계, 이미지 2/2
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: 5 단계, 이미지 1/1
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: 6 단계, 이미지 1/2 Canon Powershot A610 Speaker Replacement: 6 단계, 이미지 2/2
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: 7 단계, 이미지 1/2 Canon Powershot A610 Speaker Replacement: 7 단계, 이미지 2/2
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: 9 단계, 이미지 1/2 Canon Powershot A610 Speaker Replacement: 9 단계, 이미지 2/2
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: 10 단계, 이미지 1/1
    • Desolder the speaker at the two solder points and reattach the new speaker.
결론
Matthew Ramirez
회원 가입일: 01/20/11
625 평판
안내서 5개 작성하였습니다
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011 회원
CPSU-MANESS-W11S11G26
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 2,927
