소개
This guide will walk you through replacing a damaged speaker in your Canon Powershot ELPH 100.
This process involves soldering—make sure you are proficient at soldering before attempting this task.
Because many soldering irons take time to heat up, turn yours on before beginning. This will save you time later on in the procedure.
필요한 것
Locate the battery cover on the bottom of your camera.
Slide the tab to the right to open the battery cover.
Push down on the memory card until it clicks and releases.
Pull up on the memory card to remove it.
Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
To reassemble your device, follow the case disassembly guide in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
