주요 콘텐츠로 건너뛰기
Canon Selphy CP910 Buttons Replacement
필요한 것
  1. Canon Selphy CP910 Buttons Replacement, Body: 1 단계, 이미지 2개 중 1개 Canon Selphy CP910 Buttons Replacement, Body: 1 단계, 이미지 2개 중 2개
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Buttons Replacement: 2 단계, 이미지 3개 중 1개 Canon Selphy CP910 Buttons Replacement: 2 단계, 이미지 3개 중 2개 Canon Selphy CP910 Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Buttons Replacement: 3 단계, 이미지 3개 중 1개 Canon Selphy CP910 Buttons Replacement: 3 단계, 이미지 3개 중 2개 Canon Selphy CP910 Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Buttons Replacement: 4 단계, 이미지 3개 중 1개 Canon Selphy CP910 Buttons Replacement: 4 단계, 이미지 3개 중 2개 Canon Selphy CP910 Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Buttons Replacement, Buttons: 5 단계, 이미지 2개 중 1개 Canon Selphy CP910 Buttons Replacement, Buttons: 5 단계, 이미지 2개 중 2개
    • Turn the top panel over so the inside faces toward you.
  6. Canon Selphy CP910 Buttons Replacement: 6 단계, 이미지 3개 중 1개 Canon Selphy CP910 Buttons Replacement: 6 단계, 이미지 3개 중 2개 Canon Selphy CP910 Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  7. Canon Selphy CP910 Buttons Replacement: 7 단계, 이미지 2개 중 1개 Canon Selphy CP910 Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully remove the frame attached to the screen.
  8. Canon Selphy CP910 Buttons Replacement: 8 단계, 이미지 3개 중 1개 Canon Selphy CP910 Buttons Replacement: 8 단계, 이미지 3개 중 2개 Canon Selphy CP910 Buttons Replacement: 8 단계, 이미지 3개 중 3개
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  9. Canon Selphy CP910 Buttons Replacement: 9 단계, 이미지 2개 중 1개 Canon Selphy CP910 Buttons Replacement: 9 단계, 이미지 2개 중 2개
    • There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christie Peralta
회원 가입일: 02/01/16
751 평판
안내서 5개를 작성함
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 회원
UWT-ROSE-W16S1G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 11
전체 시간: 1,047
