주요 콘텐츠로 건너뛰기
Canon Selphy CP910 LCD Screen Replacement
필요한 것
  1. Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: 1 단계, 이미지 1/2 Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: 1 단계, 이미지 2/2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: 2 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement: 2 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: 3 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement: 3 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: 4 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement: 4 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3/3
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: 6 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement: 6 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: 7 단계, 이미지 1/3 Canon Selphy CP910 LCD Screen Replacement: 7 단계, 이미지 2/3 Canon Selphy CP910 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
결론
Christie Peralta
회원 가입일: 02/01/16
700 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 회원
UWT-ROSE-W16S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 19
전체 시간: 1,182
