주요 콘텐츠로 건너뛰기
Canon Selphy CP910 Printer Body Replacement
필요한 것
  1. Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: 1 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement, Disassembling Canon Selphy CP910 Body: 1 단계, 이미지 2/2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 Printer Body Replacement: 2 단계, 이미지 1/3 Canon Selphy CP910 Printer Body Replacement: 2 단계, 이미지 2/3 Canon Selphy CP910 Printer Body Replacement: 2 단계, 이미지 3/3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 Printer Body Replacement: 3 단계, 이미지 1/3 Canon Selphy CP910 Printer Body Replacement: 3 단계, 이미지 2/3 Canon Selphy CP910 Printer Body Replacement: 3 단계, 이미지 3/3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 Printer Body Replacement: 4 단계, 이미지 1/3 Canon Selphy CP910 Printer Body Replacement: 4 단계, 이미지 2/3 Canon Selphy CP910 Printer Body Replacement: 4 단계, 이미지 3/3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 Printer Body Replacement, Printer Body: 5 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement, Printer Body: 5 단계, 이미지 2/2
    • Use the PH1 screw driver to remove the three screws on the motherboard.
  6. Canon Selphy CP910 Printer Body Replacement: 6 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement: 6 단계, 이미지 2/2
    • Remove the printer.
    • This will prevent the printer from falling out during repair.
  7. Canon Selphy CP910 Printer Body Replacement: 7 단계, 이미지 1/3 Canon Selphy CP910 Printer Body Replacement: 7 단계, 이미지 2/3 Canon Selphy CP910 Printer Body Replacement: 7 단계, 이미지 3/3
    • Remove the output connections.
    • Be careful! Do not pull too hard because the wires might rip.
    • Output connections are located on the corners of the motherboard.
  8. Canon Selphy CP910 Printer Body Replacement: 8 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement: 8 단계, 이미지 2/2
    • The motherboard is attached to three more ribbon wires.
    • Detach these wires.
    • Be careful not to pull too hard.
  9. Canon Selphy CP910 Printer Body Replacement: 9 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement: 9 단계, 이미지 2/2
    • Separate the motherboard from the main hard drive.
  10. Canon Selphy CP910 Printer Body Replacement: 10 단계, 이미지 1/3 Canon Selphy CP910 Printer Body Replacement: 10 단계, 이미지 2/3 Canon Selphy CP910 Printer Body Replacement: 10 단계, 이미지 3/3
    • Remove the main hard drive from the printer body.
  11. Canon Selphy CP910 Printer Body Replacement: 11 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement: 11 단계, 이미지 2/2
    • Gently remove the fan from the body.
    • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
  12. Canon Selphy CP910 Printer Body Replacement: 12 단계, 이미지 1/2 Canon Selphy CP910 Printer Body Replacement: 12 단계, 이미지 2/2
    • The empty case will look like this once all the parts are removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christie Peralta
회원 가입일: 02/01/16
700 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 1-6, Rose Winter 2016 UW Tacoma, Team 1-6, Rose Winter 2016 회원
UWT-ROSE-W16S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 59
전체 시간: 4,243
