주요 콘텐츠로 건너뛰기
Carrera Mario Copter Controller Circuit Board Replacement
필요한 것
  1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: 1 단계, 이미지 1/1
    • Flip the controller over so the underside would face up
    • Remove four of 7.1mm screws with a JIS #1 screwdriver
    • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
    • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
    • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
  2. Carrera Mario Copter Controller Circuit Board Replacement: 2 단계, 이미지 1/1
    • Remove the black case to access the circuit board.
    • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
  3. Carrera Mario Copter Controller Circuit Board Replacement: 3 단계, 이미지 1/1
    • Gently lift up the circuit board from the black case.
    • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Repeat the previous procedure with the black wire.
    • Gently remove the circuit board away from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Edgar Lopez-Allende
회원 가입일: 10/20/17
207 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G6, Rose Fall 2017 UW Tacoma, Team S1-G6, Rose Fall 2017 회원
UWT-ROSE-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 266
