주요 콘텐츠로 건너뛰기
Casio FX-991EX Battery Replacement
필요한 것
  1. Casio FX-991EX Battery Replacement, Remove the battery cover: 1 단계, 이미지 2개 중 1개 Casio FX-991EX Battery Replacement, Remove the battery cover: 1 단계, 이미지 2개 중 2개
    • Remove the battery cover's screw using a Philips #0 screwdriver.
  2. Casio FX-991EX Battery Replacement, Remove the battery: 2 단계, 이미지 2개 중 1개 Casio FX-991EX Battery Replacement, Remove the battery: 2 단계, 이미지 2개 중 2개
    • Use a spudger to remove the battery using the gap to the right.
    • Don't use sharp objects that may cause harm or damage. The battery can be hard to pop out, but will do so. Dispose of a damaged battery via an e-waste collection site.
  3. Casio FX-991EX Battery Replacement, Replace the battery: 3 단계, 이미지 2개 중 1개 Casio FX-991EX Battery Replacement, Replace the battery: 3 단계, 이미지 2개 중 2개
    • The FX-991EX uses a 1.5V LR44 battery.
    • Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
    • And the negative side faces the calculator's screen.
  4. Casio FX-991EX Battery Replacement, Screw the cover back on: 4 단계, 이미지 1개 중 1개
    • Slot the battery cover back on and screw it down.
결론
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
FarmYard Gaming
회원 가입일: 08/27/20
1,853 평판
안내서 1개를 작성함
4가이드 댓글
Just discovered during a lecture that my battery has become a spicy pillow - if you're leaving this in storage be careful and monitor it, lest it explode and/or warp the case irreparably.
FarmYard Gaming - 답글
Which size of screws
李生山 -
I found nothing in the slot. What can i do?
UTL Shaion - 답글
Do you see any wires connecting the battery to the circuit board? I don’t see any on mine. Both of ours may be fake lmao
Ivan Liu -
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 153
지난 30일: 771
전체 시간: 22,337
