주요 콘텐츠로 건너뛰기
Casio LK-170 Speaker Replacement
필요한 것
  1. Casio LK-170 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Casio LK-170 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Casio LK-170 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
    • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
    • Three of these seven screws are slightly hidden and may be hard to find.
  2. Casio LK-170 Speaker Replacement: 2 단계, 이미지 1/2 Casio LK-170 Speaker Replacement: 2 단계, 이미지 2/2
    • Gently remove the speaker and its compartment from the front of the keyboard.
  3. Casio LK-170 Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
  4. Casio LK-170 Speaker Replacement: 4 단계, 이미지 1/2 Casio LK-170 Speaker Replacement: 4 단계, 이미지 2/2
    • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
    • Desolder the metal that attaches the blue and white wires to the speaker.
    • Remove the speaker.
결론
Samantha Baker
회원 가입일: 01/24/17
425 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 705
