필요한 것
Check that the position of the reverse handle is on 'OFF'
Using a small flat screwdriver, unclip the access cover to the screw that holds it in place.
Using a Phillips screwdriver, unscrew the fixing screw of the handle.
Using a 24 flat wrench, unscrew the nut counterclockwise.
Remove the inverter.
Replacing the inverter
Please make sure to properly align the pin of the diverter with the notch indicated by the arrow in the body of the faucet.
Insert the diverter into the body of the faucet.
Hand-tighten the inverter mounting nut clockwise.
Finish tightening using the 24mm wrench.
Align the reference point of the faucet body with the "OFF" marking on the handle.
Tighten the fixing screw of the handle using a Phillips screwdriver in a clockwise direction.
Put the cover back in place.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
