소개
Having suspicion that your handset is not charging well due to bad contact? You've come to the right guide!
필요한 것
Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
Remove both 5mm Phillips #0 screws to release the metal pieces.
Cut the black and red wires to finish removal, and then solder your new replacement component.
For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
다른 한 분이 해당 안내서를 완성하였습니다.
