주요 콘텐츠로 건너뛰기
Check for OBD2 codes, ABS, DTC without a scanner
필요한 것
    • Turn ignition two clicks to the ON position
    • Insert a bent paperclip into the SCC connector. (See video for where the SCC connector is located)
    • Touch both of the exposed pins to short the connection. Continue to short the connection for more than 5 seconds.
    • Any codes will display on the Odometer/Trip display, or "NO" if there are no stored codes
    • Remove paperclip and wait 10 seconds
    • Turn ignition OFF and remove key
결승점
ndsol
회원 가입일: 11/11/10
2,890 평판
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 51
30일 전: 179
전체 시간: 3,153
