소개
This is a guide to replace the battery of the Chromo Noria. Replacing the battery is one of the main important replacements. Without a functional battery, the life of the tablet ceases to exist.
필요한 것
Insert your Plastic Opening Tool into the crease between the front panel and back panel.
Slide the Opening Tool around the entire device. As you progress, you should see the device open.
Place your finger at the end of the tape closest to the battery.
Peel the tape towards the flex cables to free the battery wires.
다른 한 분이 해당 안내서를 완성하였습니다.
