주요 콘텐츠로 건너뛰기
Chromo Noria Motherboard Replacement
필요한 것
  1. Chromo Noria Motherboard Replacement, Back Panel: 1 단계, 이미지 1/3 Chromo Noria Motherboard Replacement, Back Panel: 1 단계, 이미지 2/3 Chromo Noria Motherboard Replacement, Back Panel: 1 단계, 이미지 3/3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Motherboard Replacement, Battery: 3 단계, 이미지 1/3 Chromo Noria Motherboard Replacement, Battery: 3 단계, 이미지 2/3 Chromo Noria Motherboard Replacement, Battery: 3 단계, 이미지 3/3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Motherboard Replacement: 4 단계, 이미지 1/3 Chromo Noria Motherboard Replacement: 4 단계, 이미지 2/3 Chromo Noria Motherboard Replacement: 4 단계, 이미지 3/3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Motherboard Replacement: 5 단계, 이미지 1/1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Motherboard Replacement, Camera: 6 단계, 이미지 1/2 Chromo Noria Motherboard Replacement, Camera: 6 단계, 이미지 2/2
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Motherboard Replacement: 7 단계, 이미지 1/2 Chromo Noria Motherboard Replacement: 7 단계, 이미지 2/2
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Motherboard Replacement: 8 단계, 이미지 1/2 Chromo Noria Motherboard Replacement: 8 단계, 이미지 2/2
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Motherboard Replacement, Speaker: 9 단계, 이미지 1/1
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Motherboard Replacement: 10 단계, 이미지 1/2 Chromo Noria Motherboard Replacement: 10 단계, 이미지 2/2
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Motherboard Replacement: 11 단계, 이미지 1/1
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Motherboard Replacement, Motherboard: 12 단계, 이미지 1/2 Chromo Noria Motherboard Replacement, Motherboard: 12 단계, 이미지 2/2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Motherboard Replacement: 14 단계, 이미지 1/3 Chromo Noria Motherboard Replacement: 14 단계, 이미지 2/3 Chromo Noria Motherboard Replacement: 14 단계, 이미지 3/3
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Motherboard Replacement: 15 단계, 이미지 1/1
    • Desolder the eight connections.
  16. Chromo Noria Motherboard Replacement: 16 단계, 이미지 1/1
    • Lift the motherboard to remove.
결론
Nick Rohn
회원 가입일: 10/30/16
475 평판
안내서 3개 작성하였습니다
Baylor, Team 5-6, Williams Fall 2016 Baylor, Team 5-6, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 218
