소개
This guide shows how to remove and replace the bottom blower plate for a Clarke Floor Sander 07014A. The plate seals the bottom edge of the fan into the blower housing.
The blower fan will probably be stuck to the motor axle. In order to pry the fan out, you will need two prying tools—either pry bars or hammers with long claws.
필요한 것
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
다른 6명이 해당 안내서를 완성하였습니다.
