소개
Follow this guide to remove and replace the cutting blade for the Classen Sod Cutter SC18AHDCA.
필요한 것
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket wrench to remove the six 1 inch-long bolts securing both ends of the blade. You may need to use a 1/2" combination wrench to hold the nuts in place.
Grasp the back of the blade and slide it away from the mount.
Remove the blade.
다른 2명이 해당 안내서를 완성하였습니다.
