주요 콘텐츠로 건너뛰기
Clothing Ribbon Button Replacement
필요한 것
  1. Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: 1 단계, 이미지 2개 중 1개 Clothing Ribbon Button Replacement, Clothing Ribbon Button Replacement: 1 단계, 이미지 2개 중 2개
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: 2 단계, 이미지 2개 중 1개 Clothing Ribbon Button Replacement: 2 단계, 이미지 2개 중 2개
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: 3 단계, 이미지 3개 중 1개 Clothing Ribbon Button Replacement: 3 단계, 이미지 3개 중 2개 Clothing Ribbon Button Replacement: 3 단계, 이미지 3개 중 3개
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: 4 단계, 이미지 3개 중 1개 Clothing Ribbon Button Replacement: 4 단계, 이미지 3개 중 2개 Clothing Ribbon Button Replacement: 4 단계, 이미지 3개 중 3개
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: 5 단계, 이미지 3개 중 1개 Clothing Ribbon Button Replacement: 5 단계, 이미지 3개 중 2개 Clothing Ribbon Button Replacement: 5 단계, 이미지 3개 중 3개
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: 6 단계, 이미지 3개 중 1개 Clothing Ribbon Button Replacement: 6 단계, 이미지 3개 중 2개 Clothing Ribbon Button Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: 7 단계, 이미지 2개 중 1개 Clothing Ribbon Button Replacement: 7 단계, 이미지 2개 중 2개
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: 8 단계, 이미지 3개 중 1개 Clothing Ribbon Button Replacement: 8 단계, 이미지 3개 중 2개 Clothing Ribbon Button Replacement: 8 단계, 이미지 3개 중 3개
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: 9 단계, 이미지 2개 중 1개 Clothing Ribbon Button Replacement: 9 단계, 이미지 2개 중 2개
    • Clip any threads.
    • Admire your handiwork.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,533개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 59
전체 시간: 3,100
