주요 콘텐츠로 건너뛰기
Coby KYROS MID7125 Screen Replacement
필요한 것
  1. Coby KYROS MID7125 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby KYROS MID7125 Screen Replacement: 2 단계, 이미지 3개 중 1개 Coby KYROS MID7125 Screen Replacement: 2 단계, 이미지 3개 중 2개 Coby KYROS MID7125 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger.
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    • If soldering is new for you, then follow this useful guide on soldering and desoldering connections.
  3. Coby KYROS MID7125 Screen Replacement: 3 단계, 이미지 3개 중 1개 Coby KYROS MID7125 Screen Replacement: 3 단계, 이미지 3개 중 2개 Coby KYROS MID7125 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Desolder 2 speaker wires
    • Desolder Battery
    • Desolder antenna wire
    • Disconnect all wires you desoldered
  4. Coby KYROS MID7125 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Desolder the microphone wire
    • Disconnect the wires you just desoldered.
  5. Coby KYROS MID7125 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove 4 screws that connect the motherboard to the device.
  6. Coby KYROS MID7125 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Take off motherboard by lifting off right hand side and pulling sideways.
  7. Coby KYROS MID7125 Screen Replacement: 7 단계, 이미지 2개 중 1개 Coby KYROS MID7125 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove 4 screws on corners of the digitizer and lift off.
  8. Coby KYROS MID7125 Screen Replacement: 8 단계, 이미지 2개 중 1개 Coby KYROS MID7125 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Now that the digitizer is disconnected from the screen you can replace the screen.
    • Place the screen face down in front of you facing downward and apply pressure with your thumbs around the outside of the glass to remove the screen.
    • Next, replace with your new screen and follow steps in reverse order to reassemble.
결론
작성자
4다른 기여자 명과 함께
Nicole Connelly
회원 가입일: 10/20/16
1 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 336
