주요 콘텐츠로 건너뛰기
Coby Kyros MID7024 Motherboard Replacement
필요한 것
  1. Coby Kyros MID7024 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Coby Kyros MID7024 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Begin by ensuring that the device is powered off.
    • To replace the back cover of the device you must pry it open using the access points. One is located on the top of the device above the camera and the other is on the bottom left hand side.
    • Use the spudger to pry at the access points to open the device.
  2. Coby Kyros MID7024 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Coby Kyros MID7024 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Coby Kyros MID7024 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Once the back cover begins to separate from the body of the device continue working the spudger around the perimeter of the device until the back cover is free.
    • You will hear some popping and cracking noises as you pry open the device. These sounds are the internal clips coming apart.
    • Once the back cover is free from the body of the device, open both sides like a book, placing them flat on the table as shown. Be sure to pay attention to the speaker wires that hold the two pieces together.
  3. Coby Kyros MID7024 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Coby Kyros MID7024 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Coby Kyros MID7024 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • This step is only necessary if you intend to repair or replace the back cover and/or speakers of the device.
    • In order to replace the back cover you must remove the speakers. Place the Spudger under the plastic frame of the speaker as shown. Pry up, popping the corners of the speakers out of of their bracket and lift the speaker out.
    • Be sure not to pull on the speaker's wires or body too hard as you may damage them.
  4. Coby Kyros MID7024 Motherboard Replacement, How to Unsolder Coby Kyros MID7024 Battery: 4 단계, 이미지 2개 중 1개 Coby Kyros MID7024 Motherboard Replacement, How to Unsolder Coby Kyros MID7024 Battery: 4 단계, 이미지 2개 중 2개
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the motherboard.
    • Follow the guide on soldering to assist you in removing the battery.
  5. Coby Kyros MID7024 Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Coby Kyros MID7024 Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Locate the four 5mm screws holding the motherboard in place and remove them using the Phillips #0 Screwdriver.
    • Upon removal of the screws the motherboard should be able to lift up some. Do not remove it until all of the ribbon cables have been detached.
  6. Coby Kyros MID7024 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Coby Kyros MID7024 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Coby Kyros MID7024 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the four ribbon cables shown in the yellow highlighted areas.
    • The digitizer is connected by a ZIF (zero insertion force) connector. The two black pieces on each end need to be pressed in simultaneously before the ribbon cable can be removed.
    • While pressing the black pieces, grasp the digitizer ribbon cable (widest one) with the tweezers and pull away from the connector as shown.
  7. Coby Kyros MID7024 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Coby Kyros MID7024 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Coby Kyros MID7024 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the remaining ribbon cables using the tweezers. Make sure that all ribbon cables are detatched before attempting to remove the motherboard.
  8. Coby Kyros MID7024 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Coby Kyros MID7024 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Now gently remove the motherboard from the device.
결론
작성자
5다른 기여자 명과 함께
Jacob Bartell
회원 가입일: 03/21/16
351 평판
안내서 2개를 작성함
Clemson, Team 6-3, Benson Spring 2016 Clemson, Team 6-3, Benson Spring 2016 회원
CLEM-BENSON-S16S6G3
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 476
