이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
After you open the back casing of your device you will see the insides of your device, and the battery is the silver rectangle right on top most likely taped down to the rest of the device. This guide will walk you through the replacement of this piece.
필요한 것
Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
다른 한 분이 해당 안내서를 완성하였습니다.
