주요 콘텐츠로 건너뛰기
Coby Kyros MID9042 Camera Replacement
필요한 것
  1. Coby Kyros MID9042 Camera Replacement, Camera: 1 단계, 이미지 3개 중 1개 Coby Kyros MID9042 Camera Replacement, Camera: 1 단계, 이미지 3개 중 2개 Coby Kyros MID9042 Camera Replacement, Camera: 1 단계, 이미지 3개 중 3개
    • Before removing anything from the tablet, make sure to power off the device.
    • After powering off device, remove the anti-slip pads from all 4 corners on the back of the device.
    • Once slip pads are removed, proceed to unscrewing the four 3.2 mm Phillips #0 screws from the back cover.
  2. Coby Kyros MID9042 Camera Replacement: 2 단계, 이미지 3개 중 1개 Coby Kyros MID9042 Camera Replacement: 2 단계, 이미지 3개 중 2개 Coby Kyros MID9042 Camera Replacement: 2 단계, 이미지 3개 중 3개
    • When removing the back cover, be careful not to break the inner plastic tabs.
    • Use the blue plastic opening tool to wedge the back cover apart from the front.
    • Once the edges are wedged apart, use hands to lift up the back of the tablet.
  3. Coby Kyros MID9042 Camera Replacement: 3 단계, 이미지 3개 중 1개 Coby Kyros MID9042 Camera Replacement: 3 단계, 이미지 3개 중 2개 Coby Kyros MID9042 Camera Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the gold flap and use tweezers to lift the flap up.
    • Use a second pair of tweezers to pull the gold tab connected to the camera out of the circuit board.
    • Once the tab is removed from the circuit board, pull the camera out of the tablet.
    • Caution! Be sure to avoid pulling the gold flap off the the circuit board.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
9다른 기여자 명과 함께
Samantha Rollings
회원 가입일: 03/30/15
349 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-6, Shastany Spring 2015 UMass Dartmouth, Team 2-6, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G6
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 425
