주요 콘텐츠로 건너뛰기
Coby Kyros MID9042 Speakers Replacement
필요한 것
  1. Coby Kyros MID9042 Speakers Replacement, Speakers: 1 단계, 이미지 1/2 Coby Kyros MID9042 Speakers Replacement, Speakers: 1 단계, 이미지 2/2
    • Remove the Anti-slip pads from all four corners of the back of the device.
    • Use Phillips #0 Precision screwdriver to remove the four screws from the back cover (screws are about 1/8'').
  2. Coby Kyros MID9042 Speakers Replacement: 2 단계, 이미지 1/3 Coby Kyros MID9042 Speakers Replacement: 2 단계, 이미지 2/3 Coby Kyros MID9042 Speakers Replacement: 2 단계, 이미지 3/3
    • Potential for device damage. Be careful not to break the inner plastic tabs while pulling the back cover off.
    • Gently use the iFixit opening tool to pry the back cover apart from the front.
    • After you have opened the cover, use your hands to open the tablet like a book.
  3. Coby Kyros MID9042 Speakers Replacement: 3 단계, 이미지 1/2 Coby Kyros MID9042 Speakers Replacement: 3 단계, 이미지 2/2
    • Desolder the red and black speaker wires from the circuit board. How To Solder and Desolder Connections
    • Gently remove the speakers from the tablet.
    • When replacing the speaker, remember the red wire connects to positive and the black wire connects to negative.
결론
Samantha Rollings
회원 가입일: 03/30/15
349 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-6, Shastany Spring 2015 UMass Dartmouth, Team 2-6, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 412
