주요 콘텐츠로 건너뛰기
Coil Zipper Slider Replacement
필요한 것
  1. Coil Zipper Slider Replacement, Gather materials: 1 단계, 이미지 3개 중 1개 Coil Zipper Slider Replacement, Gather materials: 1 단계, 이미지 3개 중 2개 Coil Zipper Slider Replacement, Gather materials: 1 단계, 이미지 3개 중 3개
    • Gather tools and the two pieces required for a coil slider replacement:
    • A replacement slider that is the right size and style
    • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
    • A coil top stop in the correct size
    • Coil top stops look like a small metal claw with a flat back and three prongs (one on one side and two on the other).
  2. Coil Zipper Slider Replacement, Locate the top stop: 2 단계, 이미지 3개 중 1개 Coil Zipper Slider Replacement, Locate the top stop: 2 단계, 이미지 3개 중 2개 Coil Zipper Slider Replacement, Locate the top stop: 2 단계, 이미지 3개 중 3개
    • Unzip the zipper.
    • Locate the top stop at the top of the zipper on the side with the slider.
    • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
    • Peel back any fabric that is covering the top stop.
    • Wear safety glasses to protect from projectile pieces.
    • Use end nippers or flush cutters to remove the top stop.
    • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop, then peel away the rest of the stop from the zipper tape.
    • Use a lighter to singe frayed or damaged zipper tape.
    • Slide the damaged zipper slider up and off the zipper tape.
    • Discard the zipper slider responsibly.
    • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
    • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
    • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
    • Place the top stop on the flat, tape side of the zipper, aligning the double-prong side of the stop to face the jacket and the single-prong side to face the zipper teeth.
    • Slide the single-prong beneath the first or second tooth at the top of the zipper tape.
    • Push the double-prongs through the zipper tape so they emerge on the opposite side, on the inside of the coil.
    • Use pliers to bend the prongs of the stop inward, clamping them around the zipper coil. The prongs will grab into the coil, securing it in place.
    • Check that the new stop effectively prevents the new slider from coming off the zipper.
결승점
다른 22명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,418 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,589개를 작성함
11가이드 댓글
Where do I get the zipper stop????
Jason Heimink - 답글
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - 답글
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - 답글
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - 답글
Great now how ! thank’s :)
Robert Fyfe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 44
지난 7일: 298
지난 30일: 1,144
전체 시간: 110,513
