주요 콘텐츠로 건너뛰기
ColecoVision Cartridge Reader Replacement
필요한 것
  1. ColecoVision Cartridge Reader Replacement, Cartridge Reader: 1 단계, 이미지 1개 중 1개
    • Flip the console upside down and remove the eight 15mm Phillips #1 screws.
  2. ColecoVision Cartridge Reader Replacement: 2 단계, 이미지 2개 중 1개 ColecoVision Cartridge Reader Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger along the bottom rim of the front panel to safely remove the top of the console. Set aside the top.
  3. ColecoVision Cartridge Reader Replacement: 3 단계, 이미지 2개 중 1개 ColecoVision Cartridge Reader Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Remove the casing to reveal the cartridge reader.
  4. ColecoVision Cartridge Reader Replacement: 4 단계, 이미지 3개 중 1개 ColecoVision Cartridge Reader Replacement: 4 단계, 이미지 3개 중 2개 ColecoVision Cartridge Reader Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Desolder the sides of the cartridge reader using the soldering iron and desolder pump.
    • Refer to this soldering technique guide for reference
    • Patiently wait for the cartridge reader to cool down after being desoldered.
    • It's very important to remove all the tin from the motherboard and cartridge reader before lifting it from the motherboard. Failure to do so could damage the motherboard.
    • Carefully lift up the cartridge reader. A plastic spudger might be helpful in order to easily remove the cartridge reader.
결론
작성자
3다른 기여자 명과 함께
Anastazia Kidder
회원 가입일: 10/17/18
109 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 회원
UWT-ROSE-F18S1G2
4 회원들
안내서 12개를 작성함
2가이드 댓글
If you’re removing the rivets holding the cartridge slot in place, it would be nice if you would mention what you did to secure the slot to the board after swapping the slot. I’m going to Lowe’s hardware and I will make a decent selection when I get there . I think I will be fine but it would nice to be able to have a specific size and length of screw to look for. Thanks!
Tim Boda - 답글
No need to add the rivets. Soldering the connector in place is more than enough .
Rey Lopez -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 1,889
