이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the console upside down and remove the eight 15mm Phillips #1 screws.
Use the metal spudger along the bottom rim of the front panel to safely remove the top of the console. Set aside the top.
Remove the two 15mm Phillips #1 screws holding the casing in place.
Remove the casing to reveal the cartridge reader.
이 단계에 사용된 도구:Desoldering Pump$3.99-
Desolder the sides of the cartridge reader using the soldering iron and desolder pump.
Patiently wait for the cartridge reader to cool down after being desoldered.
Carefully lift up the cartridge reader. A plastic spudger might be helpful in order to easily remove the cartridge reader.
