주요 콘텐츠로 건너뛰기
ColecoVision Controller Port Replacement
필요한 것
  1. ColecoVision Controller Port Replacement, Controller Port: 1 단계, 이미지 1/1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: 2 단계, 이미지 1/2 ColecoVision Controller Port Replacement: 2 단계, 이미지 2/2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: 3 단계, 이미지 1/2 ColecoVision Controller Port Replacement: 3 단계, 이미지 2/2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: 4 단계, 이미지 1/2 ColecoVision Controller Port Replacement: 4 단계, 이미지 2/2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: 5 단계, 이미지 1/3 ColecoVision Controller Port Replacement: 5 단계, 이미지 2/3 ColecoVision Controller Port Replacement: 5 단계, 이미지 3/3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
결론
Bobby
회원 가입일: 10/17/18
380 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 회원
UWT-ROSE-F18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 834
