주요 콘텐츠로 건너뛰기
Comfort Zone CZ6C Switch Replacement
필요한 것
  1. Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 1/3 Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 2/3 Comfort Zone CZ6C Switch Replacement, Switch: 1 단계, 이미지 3/3
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Switch Replacement: 2 단계, 이미지 1/2 Comfort Zone CZ6C Switch Replacement: 2 단계, 이미지 2/2
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
  3. Comfort Zone CZ6C Switch Replacement: 3 단계, 이미지 1/1
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  4. Comfort Zone CZ6C Switch Replacement: 4 단계, 이미지 1/2 Comfort Zone CZ6C Switch Replacement: 4 단계, 이미지 2/2
    • Cut the green and yellow wire as close to the switch connection as possible.
  5. Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 1/3 Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 2/3 Comfort Zone CZ6C Switch Replacement: 5 단계, 이미지 3/3
    • Strip the green and yellow wire about two centimeters from where it was just cut.
  6. Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 1/3 Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 2/3 Comfort Zone CZ6C Switch Replacement: 6 단계, 이미지 3/3
    • Unscrew the switch from the back panel and remove it.
  7. Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 1/3 Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 2/3 Comfort Zone CZ6C Switch Replacement: 7 단계, 이미지 3/3
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Abundis
회원 가입일: 04/08/15
169 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 회원
CPSU-FORTE-S15S17G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 2,288
