주요 콘텐츠로 건너뛰기
Commodore 64 Central Processing Unit (CPU) Replacement
필요한 것
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: 1 단계, 이미지 1/3 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: 1 단계, 이미지 2/3 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: 1 단계, 이미지 3/3
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 Central Processing Unit (CPU) Replacement, Opening: 2 단계, 이미지 1/2 Commodore 64 Central Processing Unit (CPU) Replacement, Opening: 2 단계, 이미지 2/2
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: 3 단계, 이미지 1/2 Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: 3 단계, 이미지 2/2
    • 1. Detach the multi-colored wire bundles connected to the motherboard.
  4. Commodore 64 Central Processing Unit (CPU) Replacement, Locate the CPU: 4 단계, 이미지 1/1
    • Locate the CPU chip which is labeled 'MOS 6510 3782'
  5. Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: 5 단계, 이미지 1/2 Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: 5 단계, 이미지 2/2
    • 3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Silvanus Clarke
회원 가입일: 09/26/14
656 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G6
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
Jordan Fryman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 2,658
