주요 콘텐츠로 건너뛰기
Compaq Presario CQ58 Cooling / FAN system cleaning
필요한 것
동영상 개요
  1. Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: 1 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: 1 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning, Cooling / FAN system cleaning: 1 단계, 이미지 3개 중 3개
    • Switch-off the laptop and remove the battery.
    • Remove the memory cover.
  2. Compaq Presario CQ58 Cooling / FAN system cleaning: 2 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 2 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 2 단계, 이미지 3개 중 3개
    • Remove the HDD cover.
    • Unpin the HDD.
  3. Compaq Presario CQ58 Cooling / FAN system cleaning: 3 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 3 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 3 단계, 이미지 3개 중 3개
    • Near to the WiFi card you can see one screw hole with a keyboard symbol. This screw holds the Keyboard.
    • To remove the Keyboard, you must open 5X locking clips.
  4. Compaq Presario CQ58 Cooling / FAN system cleaning: 4 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 4 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 4 단계, 이미지 3개 중 3개
    • Under the Keyboard there are:
    • 4x M2.5x5.0 screws
    • Mouse flex cable connector
    • Power On button flex cable connector.
    • Unscrew the screws on the bottom side of the laptop:
    • 13x M2.5x5.0
    • 3x M2.5x3.0
  5. Compaq Presario CQ58 Cooling / FAN system cleaning: 5 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 5 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 5 단계, 이미지 3개 중 3개
    • Use a plastic tool to separate and remove the upper case.
    • Unscrew 5x screws and disconnect:
    • LCD Display cable
    • Additional USB board cable
    • Power jack cable
    • Loudspeaker cable
    • SATA HDD cable
  6. Compaq Presario CQ58 Cooling / FAN system cleaning: 6 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 6 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 6 단계, 이미지 3개 중 3개
    • Move a little the LCD display hinge.
    • Remove the board by starting from the right side.
  7. Compaq Presario CQ58 Cooling / FAN system cleaning: 7 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 7 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 7 단계, 이미지 3개 중 3개
    • Remove the cooling system.
  8. Compaq Presario CQ58 Cooling / FAN system cleaning: 8 단계, 이미지 2개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 8 단계, 이미지 2개 중 2개
    • Open the fan and clean the dust from inside with a soft brush.
  9. Compaq Presario CQ58 Cooling / FAN system cleaning: 9 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 9 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 9 단계, 이미지 3개 중 3개
    • Clean the old thermal compound (from the CPU and from the heat-sink system).
    • Put a new thermal compound and start with reassembling.
  10. Compaq Presario CQ58 Cooling / FAN system cleaning: 10 단계, 이미지 3개 중 1개 Compaq Presario CQ58 Cooling / FAN system cleaning: 10 단계, 이미지 3개 중 2개 Compaq Presario CQ58 Cooling / FAN system cleaning: 10 단계, 이미지 3개 중 3개
    • When you start the system, check that fan is working.
    • Did you do it successfully?
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 7개
A brilliant demonstration really clear and well photographed, only one problem how the !&&* do you get the screws undone mine seem fixed solid
please let me into the secret if there is one.
thanks for the demo anyway.
JF.
alma francomb - 답글
Thanks for this!
My Son and I have just successfully removed, cleaned and replaced the fan in his laptop by following the instructions above.
Great work.
David Cooper - 답글
I think i did something wrong? I completed all the steps but my fan (which is brand new) keeps making this scary loud wizzy noise instead of a hum and did i not tightem the screws enough or they to tight?? Please help!
Layla - 답글
Please ensure the fan metal case is not bent and ensure the fan is properly mounted. If this doesn’t solve your problem, your new fan is defective.
Brendan -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 17
지난 30일: 44
전체 시간: 25,254
