주요 콘텐츠로 건너뛰기
Computer King Muffin Kinder 7 Battery Replacement
필요한 것
  1. Computer King Muffin Kinder 7 Battery Replacement, Battery: 1 단계, 이미지 1/2 Computer King Muffin Kinder 7 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Battery Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Battery Replacement: 3 단계, 이미지 1/2 Computer King Muffin Kinder 7 Battery Replacement: 3 단계, 이미지 2/2
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic.
  4. Computer King Muffin Kinder 7 Battery Replacement: 4 단계, 이미지 1/2 Computer King Muffin Kinder 7 Battery Replacement: 4 단계, 이미지 2/2
    • Unsolder the red and black wires that are connected to the battery from the logic board using a soldering iron.
    • Tips on how to solder can be found here.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katherine
회원 가입일: 01/22/15
412 평판
안내서 3개 작성하였습니다
UWT Liner: Group 2 UWT Liner: Group 2 회원
Community
4 회원들
안내서 6개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 227
