주요 콘텐츠로 건너뛰기
Conair Cord-Keeper 169XR On/Off Switch Replacement
필요한 것
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: 1 단계, 이미지 1/2 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: 1 단계, 이미지 2/2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: 2 단계, 이미지 1/1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: 3 단계, 이미지 1/2 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: 3 단계, 이미지 2/2
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Candace
회원 가입일: 01/23/14
992 평판
안내서 7개 작성하였습니다
Cal Poly, Team 10-33, Maness Winter 2014 Cal Poly, Team 10-33, Maness Winter 2014 회원
CPSU-MANESS-W14S10G33
3 회원들
안내서 7개 작성하였습니다
댓글 3개
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - 답글
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 3,050
