소개
For a sticky Cold Shot button, you may only need to clean the button. This guide will show you how to fully remove and replace the button.
Note: This guide requires soldering skills. If you don't know how to solder or want to brush up on your skills check out this handy tutorial.
필요한 것
Hold the hair dryer by the nozzle so that the handle points to the left.
Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
다른 2명이 해당 안내서를 완성하였습니다.
