주요 콘텐츠로 건너뛰기
Corsair Void Pro RGB Speakers Replacement
필요한 것
  1. Corsair Void Pro RGB Speakers Replacement, Earcup: 1 단계, 이미지 1/1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Speakers Replacement: 2 단계, 이미지 1/2 Corsair Void Pro RGB Speakers Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Speakers Replacement: 3 단계, 이미지 1/2 Corsair Void Pro RGB Speakers Replacement: 3 단계, 이미지 2/2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Speakers Replacement, Speakers: 4 단계, 이미지 1/1
    • Desolder the wire that connects to the speaker.
    • For steps on how to solder, see this helpful guide.
  5. Corsair Void Pro RGB Speakers Replacement: 5 단계, 이미지 1/2 Corsair Void Pro RGB Speakers Replacement: 5 단계, 이미지 2/2
    • Use a knife tool as a wedge to remove the speaker and glue in the new speaker.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Gianna Nobili
회원 가입일: 04/15/19
845 평판
안내서 5개 작성하였습니다
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019 회원
CPSU-MANESS-S19S9G13
4 회원들
안내서 14개 작성하였습니다
댓글 5개
Where can i find a new speaker ?
brunodehulster - 답글
The speaker listed in the parts, is not the correct speaker. I purchased them and they are NOT a fit.
ksmith - 답글
Whats the size of the speaker?
smack2k - 답글
The size of the speaker is 50 mm and about 10 mm in depth. I used this speaker in my own repair and it worked well.
noahoryan -
Can u show how to change “Charging Port”??
Jason HKB - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 16
30일 전: 32
전체 시간: 3,581
