주요 콘텐츠로 건너뛰기
Cowin E7 Extension Arm Replacement
필요한 것
  1. Cowin E7 Extension Arm Replacement, Extension Arm: 1 단계, 이미지 1/2 Cowin E7 Extension Arm Replacement, Extension Arm: 1 단계, 이미지 2/2
    • Remove four screws from the extension arm using a TR Torx 10 screwdriver.
  2. Cowin E7 Extension Arm Replacement: 2 단계, 이미지 1/1
    • Pull up on the metal clamp.
    • Squeeze the pins on the top and bottom of the side you are trying to remove.
    • This will allow the extension bracket to easily slide out of the metal clamp.
  3. Cowin E7 Extension Arm Replacement: 3 단계, 이미지 1/1
    • Replace the damaged extension bracket with a new one.
    • To insert the new bracket, remember to squeeze the pins on the side that inserts into the metal clamp.
결론
Jacob Burrer
회원 가입일: 03/26/22
439 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-2, Mellen Spring 2022 UMass Dartmouth, Team 2-2, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S2G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 30
전체 시간: 796
