주요 콘텐츠로 건너뛰기
Creating a Buttonhole Using a Sewing Machine
필요한 것
  1. Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: 1 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: 1 단계, 이미지 2개 중 2개
    • Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
    • Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
  2. Creating a Buttonhole Using a Sewing Machine: 2 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 2 단계, 이미지 2개 중 2개
    • Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
    • You can measure your button if you aren't sure.
    • Align the sewing machine at the upper left corner of the buttonhole.
  3. Creating a Buttonhole Using a Sewing Machine: 3 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 3 단계, 이미지 2개 중 2개
  4. Creating a Buttonhole Using a Sewing Machine: 4 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 4 단계, 이미지 2개 중 2개
    • Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
  5. Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 1개 Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 2개 Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 3개
    • Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
    • Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that.
    • Start sewing. Sew to your second line.
  6. Creating a Buttonhole Using a Sewing Machine: 6 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 6 단계, 이미지 2개 중 2개
    • Set your button hole dial to two.
    • Sew the bar tack at the bottom of the buttonhole.
    • Setting the button hole dial to two tells your sewing machine what to do, all you need to do is sew a few stitches to create the bar tack.
  7. Creating a Buttonhole Using a Sewing Machine: 7 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 7 단계, 이미지 2개 중 2개
    • Set your buttonhole dial to three.
    • Sew up the second side of your buttonhole, stopping at your top mark.
  8. Creating a Buttonhole Using a Sewing Machine: 8 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 8 단계, 이미지 2개 중 2개
    • Set your buttonhole dial to four.
    • Sew the top bar tack at the top of the buttonhole.
  9. Creating a Buttonhole Using a Sewing Machine: 9 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 9 단계, 이미지 2개 중 2개
    • Set your buttonhole dial to five.
    • This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
  10. Creating a Buttonhole Using a Sewing Machine: 10 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 10 단계, 이미지 2개 중 2개
    • Clip the threads, freeing the fabric from the machine.
    • Clip any extra loose threads.
  11. Creating a Buttonhole Using a Sewing Machine: 11 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 11 단계, 이미지 2개 중 2개
    • Use a hobby knife to cut open the buttonhole.
    • Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,487 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
2가이드 댓글
I got up to position (!) 2 ok, then when I tried to go back up on position 3 it didn't work and just chewed up my fabric. Is it supposed to go backwards, or are you supposed to turn the fabric around? Did I do something wrong?
Holly - 답글
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
Roszarie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 92
전체 시간: 28,854
