주요 콘텐츠로 건너뛰기
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
필요한 것
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 1 단계, 이미지 3개 중 1개 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 1 단계, 이미지 3개 중 2개 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: 1 단계, 이미지 3개 중 3개
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 2 단계, 이미지 3개 중 1개 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 2 단계, 이미지 3개 중 2개 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: 3 단계, 이미지 1개 중 1개
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: 4 단계, 이미지 1개 중 1개
    • Using a soldering iron, melt the solder in order to free the auxiliary jack.
    • 연결부 납땜 및 납제거 방법 Use soldering gun with care as it becomes extremely hot and can cause burns
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 5 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: 6 단계, 이미지 1개 중 1개
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
결론
작성자
4다른 기여자 명과 함께
Bradley McHugh
회원 가입일: 03/10/17
101 평판
안내서 1개를 작성함
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 763
