주요 콘텐츠로 건너뛰기
Creative Nomad Jukebox Zen Battery Replacement
필요한 것
  1. Creative Nomad Jukebox Zen Battery Replacement, Battery: 1 단계, 이미지 1/3 Creative Nomad Jukebox Zen Battery Replacement, Battery: 1 단계, 이미지 2/3 Creative Nomad Jukebox Zen Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Battery Replacement: 2 단계, 이미지 1/2 Creative Nomad Jukebox Zen Battery Replacement: 2 단계, 이미지 2/2
    • Use plastic opening tool to open top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Battery Replacement: 3 단계, 이미지 1/1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover.
  4. Creative Nomad Jukebox Zen Battery Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to unclip the metal bracket holding the battery down.
    • When sticker is torn warranty is void.
  5. Creative Nomad Jukebox Zen Battery Replacement: 5 단계, 이미지 1/2 Creative Nomad Jukebox Zen Battery Replacement: 5 단계, 이미지 2/2
    • Desolder both red and black wires coming from battery.
    • How To Solder and Desolder Connections Use soldering gun with care as it becomes extremely hot and can cause burns.
    • Make sure to solder the black and red wires back into the same locations.
결론
Eli Richter
회원 가입일: 03/08/17
301 평판
안내서 3개 작성하였습니다
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 25
전체 시간: 1,185
