주요 콘텐츠로 건너뛰기
Creative Zen V Plus Charging Port Replacement
필요한 것
  1. Creative Zen V Plus Charging Port Replacement, Prerequisite Only: 1 단계, 이미지 1/1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Charging Port Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Charging Port Replacement: 3 단계, 이미지 1/1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Charging Port Replacement: 4 단계, 이미지 1/2 Creative Zen V Plus Charging Port Replacement: 4 단계, 이미지 2/2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Charging Port Replacement: 5 단계, 이미지 1/1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Charging Port Replacement: 6 단계, 이미지 1/3 Creative Zen V Plus Charging Port Replacement: 6 단계, 이미지 2/3 Creative Zen V Plus Charging Port Replacement: 6 단계, 이미지 3/3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Charging Port Replacement, Charging Port: 7 단계, 이미지 1/1
    • Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
    • Learn how to solder and desolder components with this guide!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Meines
회원 가입일: 10/19/16
316 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 273
