소개
In this guide the charging port is replaced. It is recommended that you see the troubleshooting guide before attempting theses repairs, as an easier solution may be found there.
필요한 것
Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
다른 한 분이 해당 안내서를 완성하였습니다.
