이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace a dead battery.
필요한 것
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the three exposed screws (4 mm) using a #0 Phillips.
Peel off the the sticker that says "Creative Warranty Void if broken" and remove the screw (4 mm) beneath with a #0 Phillips.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
