소개
This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
부품
지정된 부품이 없습니다.
Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
When the cover has been lifted off the screen, use your hands to remove it from the device.
The button pad may fall off when the cover is removed.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
다른 한 분이 해당 안내서를 완성하였습니다.
