주요 콘텐츠로 건너뛰기
Creative Ziio 7" LCD Screen Replacement
필요한 것
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 1/3 Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 2/3 Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: 2 단계, 이미지 1/1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: 3 단계, 이미지 1/1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 1/3 Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 2/3 Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: 5 단계, 이미지 1/1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: 6 단계, 이미지 1/1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: 7 단계, 이미지 1/2 Creative Ziio 7" LCD Screen Replacement: 7 단계, 이미지 2/2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: 8 단계, 이미지 1/1
    • Carefully remove the black LCD screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle
회원 가입일: 04/16/13
120 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 13개 작성하였습니다
댓글 2개
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 답글
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,368
