소개
Is your battery draining too fast? It no longer holds a charge? This tutorial will show you how to remove the old battery from your smartphone and replace it with a new one.
Crosscall does not provide spare parts on its older models, so you will have to find this battery yourself.
If you use another battery model, check that the connectors, dimensions and position of the power supply wire are correct.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
필요한 것
Remove the 10 hexagonal screws.
Open the waterproof cap of the USB socket and remove the 2 Phillips screws (see photo 2).
Open the waterproof cap of the earphone socket and remove the Phillips screw (see photo 3).
Lift the rear panel which should come without forcing.
Unscrew the four (4) Phillips screws to release the black plate supporting the SIM card.
Gently lift this black plate and release the connector with the flat end of a spudger. (The connector is visible in photo 2 when the black plate is separated from the device)
Unscrew the metal plate protecting the battery (4 Phillips screws).
Disconnect the battery connector with the flat end of a spudger (use a plastic spudger to avoid a short circuit).
Lift the metal plate stuck to the battery (to extract it) and gently pull on the NFC sensor socket (you have to pull towards the bottom of the device to disconnect it).
With the battery separated from the smartphone, remove it from the metal plate with a suitable solvent
Be careful not to bend or puncture the battery during this procedure: A damaged flexible lithium-ion battery may leak dangerous chemicals and can catch fire and even explode!
Insert the new battery.
Connect the connector for the power supply using a plastic spudger.
Replace the metal plate and slide the NFC sensor connector into its socket.
Insert the 4 screws that tighten the metal plate.
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 11개
Bonjour
Merci beaucoup pour votre tuto.
J'ai installé la batterie mais elle ne se charge pas : en fait le témoin de charge s'allume; il s'anime bien mais la batterie ne se charge pas .
S'il vous plait sauriez vous d'où ça vient ? J'ai du mal à réintroduire à fond la petite prise NFC : est ce que ça vient de là ?
Merci beaucoup
Albert
meme problème rencontré apparement la batterie de trekker m1 ne fonctionne pas avec m1 core malgré que les batteries soient identiques...
LCD Expert - 답글
Bonsoir , même problème ,pas de charge pourtant il se connecte bien au pc ,mais il ne charge pas, où est l erreur ?
