소개
This guide will walk you through the process of replacing the rear wheel of your cruiser bike. You will need to replace your wheel if it is flat or continues going flat. This process can be tricky, considering the parts associated with the rear wheel. Make sure you have the correct tools for the job and follow the directions strictly. The most strenuous part of this repair is flipping the bike.
필요한 것
With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
Tighten the non-drive side (side without the chain) first.
The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
Use a tire pump to make sure the tire is full of air and ready to ride.
다른 2명이 해당 안내서를 완성하였습니다.
