주요 콘텐츠로 건너뛰기
CrystalView NB4-35788 Auxiliary Speakers Replacement
필요한 것
  1. CrystalView NB4-35788 Auxiliary Speakers Replacement, Auxiliary Speakers: 1 단계, 이미지 1/1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Auxiliary Speakers Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Auxiliary Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Auxiliary Speakers Replacement: 4 단계, 이미지 1/1
    • Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
  5. CrystalView NB4-35788 Auxiliary Speakers Replacement: 5 단계, 이미지 1/1
    • Gently pull up on the speaker to remove it. Repeat this for the other speaker.
  6. CrystalView NB4-35788 Auxiliary Speakers Replacement: 6 단계, 이미지 1/2 CrystalView NB4-35788 Auxiliary Speakers Replacement: 6 단계, 이미지 2/2
    • De-solder the red and black wires to disconnect the old speaker.
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
결론
Alex Stokes
회원 가입일: 01/12/17
101 평판
안내서 1개 작성함
Oakland University, Team 2-6, Ruskiewicz Winter 2017 Oakland University, Team 2-6, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 135
