필요한 것
Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
By the end of this guide< you will have successfully replaced the power cord to your device.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
I need one also. drshtender1@gmail.com
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
