주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Curtain Rod Bracket Replacement
필요한 것
  1. Curtain Rod Bracket Replacement, Bracket: 1 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement, Bracket: 1 단계, 이미지 2개 중 2개
    • If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
  2. Curtain Rod Bracket Replacement: 2 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement: 2 단계, 이미지 2개 중 2개
    • Observe the hole of the screw(s) that was ripped out of the wall.
    • Determine whether the plastic anchor will fit in the current size of the hole.
    • If the hole is smaller than the anchor, continue to Step 3. If the hole is bigger, complete this guide on patching a hole in dry wall.
  3. Curtain Rod Bracket Replacement: 3 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement: 3 단계, 이미지 2개 중 2개
    • Use a ¼ inch drill bit to drill the hole(s) that the anchor will be placed into. Drill into the wall and continue drilling as you pull out of the wall.
    • Avoid placing hands near the drill bit while in use. If you have medium to long-length hair, tie your hair back to avoid possible injury.
  4. Curtain Rod Bracket Replacement: 4 단계, 이미지 3개 중 1개 Curtain Rod Bracket Replacement: 4 단계, 이미지 3개 중 2개 Curtain Rod Bracket Replacement: 4 단계, 이미지 3개 중 3개
    • Hammer the hollow wall anchor(s) into the hole until flush with the drywall.
  5. Curtain Rod Bracket Replacement: 5 단계, 이미지 1개 중 1개
    • Paint the wall anchor and any surrounding area that has been damaged so that it matches the wall.
  6. Curtain Rod Bracket Replacement: 6 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement: 6 단계, 이미지 2개 중 2개
    • Screw the bracket into the anchor(s) with a screwdriver. The bracket will be secured to the wall.
  7. Curtain Rod Bracket Replacement: 7 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement: 7 단계, 이미지 2개 중 2개
    • Touch up with paint if necessary.
  8. Curtain Rod Bracket Replacement: 8 단계, 이미지 2개 중 1개 Curtain Rod Bracket Replacement: 8 단계, 이미지 2개 중 2개
    • Rehang your curtain rod and curtains by placing the rod onto the bracket.
결론
Enjoy your renewed privacy!
작성자
1다른 기여자 명과 함께
Ashtyn Drake
회원 가입일: 10/14/22
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 67
전체 시간: 1,361
